Discuss Flue bracket regulations in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The flue runs up from the boiler into the attic. There are then two 45 degree elbows before the flue runs out to the rroof.The flue runs parallel from the boiler to the bit going out of the roof with an angled bit in-between. Where by regs should the brackets go and how many will be needed?
I only went to look at the flue today .It was serviced and the owners were advised to add brackets to bring it up to regs. Whoever serviced the boiler didn't turn it off and allowed it to run as it has been since it was installed a few years ago.
I'm not gas safe registered. I went to do a few other jobs at the house and was asked about the flue brackets whilst I was there. I said I'd ask and see exactly what needs doing.
That’s not what he said, plus why would you anyway? Doesn’t give off the right impression in my book, spend a few quid more and the job is bob-on.
Right = Right.
Depends how it is ran. I would never use it. But if it done correctly it should be fine.
Needs to be manufactured approved method strap banding isn’t
I’m sure I saw a bulletin some where that said as long as it goes around the flue and is tight to opposite beams it is ok. I’m not that bothered anyway as I always use Worcester flue brackets. I was just saying that I’m sure I saw it somewhere.
Strapping is not allowed.
You need a bracket on each stretch as a minimum
You also should have a bracket at the top, as it exits, in addition to the others.
So, technically, 4 brackets as a minimum.
The whole structure must be perfectly rigid, otherwise more may be required (speaking generally, probably not an issue in this case)
Also had two Gas Safe inspectors just recently tell me the same thing, Strapping is not allowed and has to be a proper flue clip on every length of pipe. We've always used clips anyway as I hate the strapping so didn't matter, but i've seen many that have been strapped.
My view is that if you go to a job that's old and it's strapped and adequately supported & secure then it's fine. But on any new installations they should be flue clips.
Getting back to the OP, needs 3 clips on that flue.
I always just put on what ever I've been given so baxi supply 1 per length plus 1 for the vertical terminal so I'd put 3 on that if it still feels loose I'd chuck another on.
I always thought it had to be 1 per length and every change of direction but I have no idea where that came from so don't quote me on that as I may of just dreamt that.
And I also thought you couldn't use banding anymore. Was told that by a bg inspector when I subbed to them years ago and also by the gas safe inspector when he saw it on the van.
No they are not. Regs are legally superior to MI’s contrary to the well held assertion.
Manufacturer instructions over rule regs
I was always under the assumption manufacturers requirements overrule regs. This is only what I've been told though, probably the same as others. @firemant can you put a link to either prove your statement or disprove HF's?
HaHa. I was waiting for that, and I will. But I am not at home at the moment.
But, for now, a Regulation is exactly that.. And is part of Law. That is not to be confused with Standards, which are not. A manufacturer, or,indeed an engineer, can use a method not in the Standards - but may be called upon to explain why their methodology is as or more apt.
Realistically, does this scenario happen often? How many times has someone came across a situation where by the regs it was wrong, but right by the manufacturers instructions?
Surely manufacturers are required to produce their appliances so they fully comply with our regs and not just used as a guide?
I would say though that regarding the flue in this thread. The "standard" would be to clip at every change of direction and just before if leaves the roof. But if the manufacturers produced their flue so that when pieced together it was rigid, and they stated only 1 clip at the exit was needed, then this would be acceptable.
So basically what you are saying is that regs say 1.8m but if MIs state every meter or change of directions this can be ignored and 1.8m can be used?
No. You have to follow MIs, but they cannot over rule Regs. They can obviously demand higher specs, and of course you can work to higher standards.
But my point is that MIs are not superior to Regs, which is what folk keep saying.
so lets say
clipping distance
regs every 2m
mi every 1m
you would go off the regs then
quite a bit regs want flues screwed every joint for viessmann this is a big nono as it states in the mi do not screw the flue as with expansion the flues split
Reply to Flue bracket regulations in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We are considering buying a house which currently has a 20 year old Ideal Icos boiler, so we're factoring in replacing the boiler soon. Current...
I'm remodeling our master bath. We have two 30 inch vanities with a 24 inch open space between them. Drain pipes go down into the basement of...
My installation has been classed as Dangerous 'Do not use' by my boiler manufacturer. I have an Ideal Logic 30kw Combi boiler mounted as high as...
E
Hi all, Apologies if this has been covered elsewhere but I can't find an answer to my questions. I have a back boiler and gas fire which h has...
