Discuss Flue issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Common sense ?Does it contravene anything though?
not a reg!Common sense ?
good! Anything else.What about No flue guard .. Below 2 meters
Yes my guess would be it should be raised and also protected from damage ?
That is just being awkward for the sake of it ?how about it shouldnt be there, fullstop!
There is nothing to say you cannot have a flue or a chimney coming up through a roof terrace or even a patio as we have built underground rooms before extending into the garden with the chimney being built up from ground level .
In this case yes it needs raising and either protecting or a brick structure but the flue position is ok .
There is more than one way to solve any problem I only say brick but timber may be easier ,and it would not have to be plastic ?So you build a brick structure round it and raise it, how are you going to inspect the flue, stick a plastic door in the chimney you have just created?
Well someone must have beeen signing his landlords certificates I guess ?From the photo it maybe better to take it horizontally out into the garden, the flue was fine until the decking was completed. It now needs updating, how wold anyone think it's right?
Not all jobs fit in to what we consider to be normal so there will always be the odd one that takes some thinking outside the box ?
No not at all I am suggesting that it is not always possible to have things as nice straight forward ticks all the boxes at first glance .Are you seriously condoning an illegal gas installation?
Because it's not installed as per manufacturers instructions,.
So I'll ask again.
Are you seriously condoning illegal installations?
Reply to Flue issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
