Discuss Flue termination over next doors drive in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Snowhead are you saying if my next door neighbour has his boiler flue on my land I cannot build my extension? I cannot see that happening
A lot of folks need to go and revise their building regs about flue termination!
It's no different to capping a chimney with a working fire below it, you wouldn't and couldn't do it.
Building control wouldn't let you build up against the flue.
The flue would be existing, it should never have been there but as a neighbour how are you going to get around it without negotiating to have it moved.
I've seen flues on end terraces discharging over public foot paths at high level.
building control wouldnt care as planning would have been passed and the new build would go in and the flue owner would have to sort themselves out as they are in the wrong and its not their neighbours problem!
Do you mean it physically terminates or that the plume is likely to head in that general direction. Its 600mm but you can get deflectors for some flues that directs the plume at an angle away
If the existing flue contravenes building regs you can force them to move it. It's their problem. Which is why you should not terminate a flue over a neighbour's boundary even with their permission. If they sell up the new owner has every right to insist on it being moved.
Planning have no concerns over Building regs.
Building Control would spot there was going to be a conflict when the footings are inspected.
How would you "Force them"?
A private prosecution for failing to comply with Building Regs?
Has anyone on here ever moved a boiler / flue as a result of a Legal ruling obtained by a neighbour?
yup, they didnt need a ruling, the new neighbour was built like a proverbial shed and pointed out the fact he no longer wanted a steam plume in his back doorway :) So I installed a vert flue through the roof.
If somebody did that to me I would take my mash hammer and adjust the flue accordingly, shouldnt be done, cant be done. Simples :)
As far as my concern you are not allowed to use the old flue termination based on the new technical bulletin.
I am quite sure you will need to change the flue.
Based on my recent gas course you will need to change it
No need for a private prosecution. The new owners went to local authority building control and lodged a complaint. The neighbours had to move the boiler in their expensive new extension. This was Redbridge council and I got the job of moving the boiler as the homeowner understandably did not want the original installer back.
What people don't seem to realise is that unlike Gas Safe rules, Building Regs are actual statutes. The full force of the law is behind them, and local authority building control can enforce them, right up to forcing people to knock down extensions, new builds etc. Fines can be in the tens of thousands and chronic failure to comply has in the past led to jail terms.
Reply to Flue termination over next doors drive in the Plumbing Jobs | The Job-board area at PlumbersForums.net
