Discuss Fluke T5 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Alex Beckett
Hi.
I'm looking at changing my electrical testing equipment. At the moment I use a cheap multi meter from maplin's that ive had for years, although this isn't really up to the job and is quite bulky.
I primarily use it for testing boilers and heat pumps so need to be able to measure quite a wide range of resistance and amps etc for thermisters, temp sensors, coils and such like.
Has anybody used/owned one of these Fluke T5's if so are they up to the job and able to measure the range of resistance and 'ampage' that say a 115 could?
Alex.
Hi Darren,
Thanks for the reply.
Do you use the T5 for boiler diagnostics? It has the range for measuring the very low amount of resistance/micro amps etc that some boilers require?
Many thanks?
Alex.
i use the fluke and also have a multimeter but i hardly ever use the multimeter
I use the 116.
It does all I want apart from heavier amp stuff but I've got other gear for that.
The 116 is aimed at HVAC folk and well worth the money !
I use the 116.
Reply to Fluke T5 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
