Discuss Flush valve washer needed - nobody seems to supply this size in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Lecica Toilet is quite old (+15 years)
I phoned the manufacturer but they sent me a standard washer for the Lecica Cistern flush Valve but it does not fit!
Dimensions for the one i require are:-
Inside diameter: 75mm.
Outside diameter: 57mm.
I assume you mean 75mm outer 57mm inner not the other way around.
That would make the washer only 9mm wide, that's seems narrow?
yip that is right 75mm outer 57mm inner it is why i cant find one
Here are the pics
Have you tried flipping the washer over ?
Too small its only 70mm anyway also too thick already thought of that just thought someone might know where to get good spares but most of the suppliers dont list the dimensions of the items which makes it even harder to find one that might fit
Its lecico toilet been told they are foreign cr**
That’s strange shouldn’t have an error
If you check the file i attached when i click reply to your message it puts in that orange box with the html then the sites rules checker marks it as "naughty" and so doesnt allow you to post the reply i am a computer programmer seen it lots of times on the old BBS forums from 30 years ago this forum is probably based on that old code - really out of date its why these type of forums are not popular anymore as they are slow, buggy and unix based like the old Prestel BBS systems!
Reply to Flush valve washer needed - nobody seems to supply this size in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I have tried hard to get similar to the first class satchwqell /Sunvic SML type revolving type valves instead of the quite short lived spring...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
Replaced like for like flush valve in Ideal Standard cistern, but do not seem to get more than half filled, giving insufficient water for...
3K
Does anyone know of a decent flush valve to fit the Ideal Standard SPACE cistern, that is better than the piece of carp fitted as OE please? It...
2K
Hello I want to replace the old single panel rad in the bedroom with a K2 double panel Stelrad one. I think I'm OK in general and relatively...
