Discuss Flush water not discharging all the way round rim of bowl... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, my Twyfords flushes OK but the water doesn't circulate round the rim, it just flushes out 2 or 3 inches either side of outlet. There's a 'widget' thingy tucked up inside the rim at the outlet point and I assume this is suppose to direct the water horizontally beneath the rim but it's loose. Anyone got a diagram of how this 'widget' thingy should be seated. Many thanks.
Or is the widget thing a part of the flush mechanism that has fallen down the flush hole? Had that happen to me once and never did find where it ended up - in your toilet, perhaps?
Is it a low level pan with a flushpipe between the cistern and toilet pan?? Could be that the outlet in back of pan is partially blocked?
Thanks for your replies. It's a low-level with flush pipe between cistern and pan. I think its a deflector widget thingy and I've sussed how it works now - have managed to get fingers up under the rim and turned it up the other way. It can't have dropped through from cistern because I couldn't push it back, but the water now gushes right round the bowl with no problem. Many thanks once again.
Reply to Flush water not discharging all the way round rim of bowl... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
