Discuss Flushometer toilet on residential pressure tank in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I'm installing a new well pump, pressure tank, and toilet in a "shed" (note: local code is 2015 UPC based, and shed is insulated & conditioned) For some specific reasons I need to install a wall-mounted toilet. A "typical" well-performing model with an in-wall tank runs > $1000. There are cheaper models, all in ~$500, but they have poor reviews on performance.
I am looking into using a commercial Flushometer, such as American Standard AFWall FlushoMeter. ($200 all in) These are tankless, and thus take very high flow rates.
The toilet is adjacent to where i will install the well pressure tank. The model above quotes 25gpm and 25 psi (flowing)-80 psi (static) pressure. That seems like no problem, being adjacent to the pressure tank & using suitably sized inlet pipe.
How successful will the toilet be? They seem to have a bad rap in residential - but I assume this is just for folks pulling their water over a ~100ft 1" pipe & a bunch of fittings from the city? Eg they would work well even there if a bladder/accumulator was installed??
Some additional information, namely about the well system: this is a property we intend to build on eventually, and have a well drilled w/ good flow. That will be several years, so in the meantime I'm putting a small "shed" on it to allow us to hook up to power & sewer and use the property for ~RV'ing. The toilet will be inside the shed, allowing comfortable use in the winter.
I have not yet chosen my pump, and am still deciding between VFD/variable, and "standard" pump with full bladder tank(s). I'm leaning to the latter, but plan on posting a question about that.
The standard variable drive pump install seems to use a couple gallon ballast tank that fits IN the well shaft; I imagine that if i go this way, and use the Flushometer, i'll need to add a bladder for the toilet (as I won't have the large pressure tank to buffer it's draw).
Reply to Flushometer toilet on residential pressure tank in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
