M
mikeds
I'm trying to replace the ceramic valves in a Franke Olympus tap. I have removed the grub screw from the tap lever, but the lever wont budge, so I cant gain access to the valve. Any ideas?
Discuss Franke Olympus - valve replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Thanks Best, but the handles on my tap are a single unit incorporating the spline. I think I have seen mentioned very similar handles that unscrew, but the ones I have do not.....so without being able to remove the handle from the spline I cant fully remove the shroud and get access to the valve unit.
Reply to Franke Olympus - valve replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
