Discuss Franke Tap Valve - special tool for removing? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
Just bought a new Franke valve but once I took the cover off it appears to be different to what I expected - no hex nut, just two slots. Where can I find a tool to remove the old one - looked every but can't find one plus is there a 'normal' valve underneath this? Photo attached if anyone can help please.
Thanks all
you could try tapping it lightly with a driver and small hammer to loosen the split nut dont go mad though, or phone franke they to see if they know of a tool
Think thats been tried looking at the burr that`s been created.
Pair of either good quality or £1 shop, long nose pliers and a bar/screwdriver to twist them.
Or piece of flat bar, (or hardwood) hole in it big enough to get the spindle through and 2 nails or screws to line up with the slots.
Reply to Franke Tap Valve - special tool for removing? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
