Discuss Franke Tap Valve - special tool for removing? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Ron still pop in from time to time hope life's treating you well...regards Turnpin:)
I think it does and I appreciate it a lot. It is nice to see you on here and still helping out others. Are you a lot busier now? If so that’s great and well done you. Hoping to see you more often
Thanks to all, ESPECIALLY the reverse thread bit.
I drilled two holes in either jaw of an adjustable, 3.5mm big, put two socket screws in the holes.
Now all I need is a new cassette.
Reply to Franke Tap Valve - special tool for removing? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
