Discuss Free guide to drilling and notching joists. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Nah, sold it at an antiques fair made enough to buy a LG nexus 4 and sold iPad and got nexus 10 :) whose a clever boy ? Moi ?
I have no idea what any if that meant. I only understood iPad because its what I've got because I'm a cool geezer :)
Life would be so much easier tho if you were a Stetson wearing herd wrangling horse whopping cowboy. You'd make loads of money doing whatever you saw fit. The worst that will ever happen is a quick conversation with Dominic littlewood on TV which is free advertising anyway lol
If you have the "I don't give a carp about anybody but me" attitude, then you could quite easily end up rich.
I`m not saying its a good idea to go around notching willy nilly. But, in almost 30 years I have never seen a ceiling or floor suffer due to someone notching out too much or in the wrong place. Is it just me?
If I mention notching in front of my dad it becomes a heated argument, him being an old time joiner who says joists are the way they are for a reason and me trying to explain current regs allow it as long as they're followed by the book. Always ends with us silently sipping our pints and avoiding eye contact.
Dads eh.......:)
I've seen a few. Worst one was a job done by the firm I worked for. Guy ran a new gas line across the joists to the new boiler position. Trouble was they were only 4" joists and he notched over an inch out using the saw and hammer method to make it worse. The customer noticed that the floor was creaking alarmingly and the ceiling below cracked. Upshot was a structural engineer was called in and the joists all had to have steel plates bolted either side. Cost the company a fortune.
When we had the family business we used to carry out investigative works for a firm of structural engineers and I've seen plenty of issues with badly notched joists.
If you notch/drill willy nilly and something goes wrong you haven't got a leg to stand on. If you follow the guidelines you've got a defence.
problems are worst with more modern construction method which have less load bearing walls and longer joist spans. older house's tend to have short spans between solid walls so its not such a big deal.
now if only somebody could post this in the electrcial form? ive never seen a sparks who could dril 3 holes in a straight line, never mind in an actual drill zone LOL. Also never meet a sparks who could drill a hole through a joist straight, normally at 45 degree angles.
Have you seen them new joists 'i-beam' shaped that you can run a soilpipe through?
new, i think your a number of years late to the party LOL.
they are good and like you say you can drill very big holes in them, you do need to keep holes so far apart but generally they are very helpful for pipe runs.
Everybody else does. The best is when ppl try to repair a joist by nailing a bit of wool to the side of it where it has been drilled/sawed too much.
ive never seen this happen, is it just in wales this happens?
Its always nice to see information thats so easy to read and comprehend.........not. Lol.
I understand drilling and knotching new build but never known anyone even give zones a thought on refurbs. The main run would normally go across landing to a/c and pick up rads to the most convenient route. Asked the question "where are the zones for knotching" to many fitters when installing hearings and no-one could answer.
I had a floor on a bathroom last month that we had to sort where the previous plumber had notched too much. We put in a new floor above the old one, hung with joist hangers off the brickwork. This was as the property is in a big victorian flat, and putting in a new floor would have meant disturbing the flat below.
The floor was springy as hell.
Also my brother once notched out a floor, right across the centre of the room. My dad went mental at him, the floor was like a trampoline. This was about 15 years ago. Sure he's learned by now.
We had to 'flitch beam' that floor. (bolting steel plate to each side of the joists).
It is important to get notching right, but I just use common sense.
Also with plastic pipe, most people just use an angle drill which leaves a bit of meat each side of the joist.
most landings have load bearing walls underneath in older house designs, i agree there are plenty of installers who have no idea what the requirements are and that goes for new builds to. ive seen plenty of sparks drill though the top and bottom of engineer'd joists, its scary sometimes to think how poorly trained and informed some people are. If you can notch a joist correctly how can you be expected to create a tank stand to hold 1/4 tonn plus of weight.
The guide I've given is from Zurich Building Insurance. Incorrectly notched or drilled joists not done to their guidelines could invalidate a building insurance policy.
Just seemed difficult to read thats all.
Perhaps its just me?
I get it now, just had to study it a little longer.
Reply to Free guide to drilling and notching joists. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks ok to me.....sound but the bowl has seen a lot of work. So she wants a new one...Astracast it seems are no more. The problem is its size.....looked...
I have a brand new, unboxed shower/wet room screen from KRION purchased from Porcelanosa UK. It is the Attica 1 model, as shown in the attached picture from their catalogue. Like on this image ->...
Sebastian T
