Discuss Free standing bath taps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
king of pipes
Subscribed
Any of you come across this problem something is not right here ? Cheers kop
Grub screw on the tap end ?
Flexi end fits down to the deck via the blue steet plate then chrome cover hides it up I think they are the wrong taps no grub screws in the legs either ? Soak .com should be Rubbish.com ,customer service crap not a clue . Kop
Well come on share the fun
Look way down in there is a a female 3/4 bsp thread wasnt obvious and no fitting instructions soak.com confirmed correct products but no manufactures fitting instructions available, now fitted and connected into the supplies so time will tell floor to be plyed karndean going down walls to be paneled then it's fitting out . Cheers kop
To be honest if I had to make a connection to a tap that I couldn't leak test a flexi or a speedfit hand tight connector would be my top choice. Check all surface clean and smooth, no debris, nipped up past hand tight, no twisted, chances of a leak are miniscule. But would still rather be able to check!
Reply to Free standing bath taps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
