Discuss Fully pumped CH systems? Potterton Profile 80e conventional boiler. in the Central Heating Forum area at PlumbersForums.net
AFAIK the boiler is set to fully pumped. (The switch inside is on fully pumped), however the pump is only running while the boiler burner is actually lit.
My understanding is that a fully pumped system should have the pump running for a while after the burner goes off to circulate the heated water around.
Looking at the boiler diagrams, there is a pump over run thermostat that is used when set for fully pumped, which keeps the pump running until the heat exchanger temp drops below 80c.
This stat is fed from a terminal marked Switched Live. On this installation, the Switched Live terminal goes up to the main terminal box but is not connected to anything! I assume it's supposed to go to a room stat or something?
The manual says to connect it to permenant live if there is no 'external control' fitted.
Is there any reason why this would not have been wired up? Should the pump actually run for a period after the burner shuts off?
The rads take a while to warm up and if the HW or UFH circuits are off, they take forever to warm up. I am thinking that this is because the pump isn't over running.
Reply to Fully pumped CH systems? Potterton Profile 80e conventional boiler. in the Central Heating Forum area at PlumbersForums.net
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
Hello. I've just replaced our old Potterton EP2 CH controller with a Drayton Wiser HubR (& peripherals). The old backing plate wasn't...
Hi, i've got a job with a Vaillant Ecotec 630 system boiler, and i don't know the full history but the house has definitely been extended...
Can anyone help, please? I'm looking for a heating system circulation pump for a domestic install, with 3 speeds, where the speed can be toggled...
Hi everyone Some very helpful people on this forum (hi John.g) sorted me out with some issues with a faulty installation of a Grundfos UPS3 back...
