Apparantly the G3 regulations have changed to include domestic hot water system under 15 Litres. this means if you dont have G3 qualification you can no longer install under sink water heaters
In the previous addition of the regulations unvented vessels with a storage capacity of 15 litres or less were excluded from the regulations.
This is no longer the case but the approved document states:
3.19 Water heaters with a capacity of 15 litres or less that have the appropriate safety devices for temperature and pressure will generally satisfy the requirement set out in G3(3) (part of the regulation relating to hot water storage)
Thus it should be OK to carry on as before as long as the water heater has the appropriate safety devices.
If you read it in context then it is basically saying that as long as the unvented heater is brought as a package with the appropriate safety devices (there must be two independent devices in addition to any control thermostat) then the regulation is deemed to have been satisfied.
Hope Im not causing trouble with this post but I was on a course last monday and was told this by the tutor so it will be good to find a full clarification
Hi
I know this is an old post but i was wondering about a new change to G3 regs regarding temp and pressure relief and safety relief going in to 2no separate tundishes as i have heard it is coming as an amendment to the regs, but not sure when?
Peter
there are no changes to the regs demanding this, usually in training we get a heads up to amendments that are on the way, to date i dont have any notification that changes are coming, if i hear of any i will post
