Discuss galvanised steel reducer to copper in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi Guys,
I am looking to replace radiator as the old threaded valve is shot on this old building but it is attached to what looks like 1 inch galvanized steel. I was hoping to freeze the pipe at the bottom (see pic) cut and reduce into 15mm copper, any ideas if there is a suitable adaptor out there for this? Any ideas greatly appreciated.
Cheers
IF that pipe is 1/2" BSP = about 20mm
You'll need an adaptor for both ends, think I'd drain down the system than trust a can of freeze.
https://www.NoLinkingToThis/p/floma...D3UVEwzUdWlYl1TTgWwaAmqrEALw_wcB&gclsrc=aw.ds
You can still get commercial eg steel threaded valves danfoss
1/2 is 3/4 od
3/4 is 1” od
Thanks for quick response guys.
it is definitely 28mm (1 inch), I have a rothenberger pipe freezing kit which has not failed me yet! There are 26 rads on the system so want to avoid drain down! I did have a look a at the old threaded valves to replace but I could not find 1 inch fitting, I was not thinking about the internal diameter so a 28mm should work perfectly. Thanks for the help guys.
Cheers
Cheers
3/4” danfoss rad valve
1” measures 11/4 od
Reply to galvanised steel reducer to copper in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
