Discuss gas fire - choosing the one in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Viper Gas
hello,
ust like sizing a boiler is there a similar process when choosing a new gas fire?
thanks
dd368
No there is no sizing for gas fires.
I would just go for the biggest output and looks for your type of flue.
The only thing to remember is any appliance over 7Kw gross input will require a separate air vent so I would advise picking a fire under that.
and make sure it will fit your fireplace and work on your flue system.
And if its flueless, check the size of the room its going in....
If it is flueless, I would not bother fitting it. I would invest in a box of candles and place a few on top of the fireplace.
Will look better, produce more heat and be a lot safer. Will also save you the hassle of putting in ventilation.
Reply to gas fire - choosing the one in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
