JTplumbingservices
- Messages
- 234
That’s an option too mate , now I know I can work on that side I’m sorted. Thanks again for your helpDesolder the elbow or drill a new hole lower and adjust pipework outside ?
Discuss Gas meter relocation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
So that’s the job done and all tested and working.Desolder the elbow or drill a new hole lower and adjust pipework outside ?
However, I had to cut out the internal ECV and use that because the fitting I got didn’t fit into the anaconda.
I ordered a 22mm - 3/4 male straight adaptor but it was too small, the lip on the Anaconda wouldn’t fit inside it.
Here is a pic of the fitting.
Any ideas because I think I’m going to have a few of these to do.
ah ok mate, here it isNo picture mate 5 words
I’ll have to get them onto that then, I just hand my order line into our store and they give me it from their stockthe second link i gave you was an adapter incase the male iron internal dia was too big (thought it might be)
eg
Gas Meter Adaptor 3/4" BSP TF x 3/4" BS 746 M - 0181 | BES.co.uk
Order 3/4" BSP TF x 3/4" BS 746 M gas meter adaptors and pipe fittings online at BES.co.uk. Low Prices, Free Next Day Delivery Available, 15k Plus Products in stock. P/N: 0181www.bes.co.uk
The outside reg is the only one.reg attached to the ana? as tbh you dont need it as its already down to working pressure eg 20mbar from the reg outside in the meter box
so you could use two gas meter connections etc (thats if the reg outside is working )
They had fittings on the meter so the anaconda went straight into it.
I know what you mean though I could have just used a tail and hard piped both sides ?
For future ones where ana is at the meter I’ll need the proper fittings to connect onto it though , as I will have to fit a new AECV which will be a lever valve with compression at both ends.
I get you mate.tbh unless its on a reg all meter connections should be hard piped
the anas only there for the high pressure side eg before the reg (yes its still only low pressure eg .75mbar + )
you could just use two meter connections eg
Gas Meter Union - 1" x 28mm - 20353 | BES.co.uk
Order 1" x 28mm gas meter unions and other gas meter fittings online at BES.co.uk. Low Prices, Free Next Day Delivery Available, 15k Plus Products in stock. P/N: 20353www.bes.co.uk
and stick a lever valve before the inlet to the meter hard piped
I get you mate.
Just to confirm though for future when the ana is on a reg and I have to use it and I have to get to copper from it the correct fitting should be the 3/4 - 3/4 adaptor you posted a couple of messages ago just with a 22-3/4 screwed into it ?
Is there just a better way of doing this type of job all together you’d recommend?correct if going onto an ana tbh there not that much might be worth trying one to make 1000000% sure
Oh on that note, my supervisor is adamant it can be moved 2m , has that ever been the case ?depends whats in the way you cant move it more that 1m away and you need access to the ecv so hard pipe it remove the ana out of the reg and install a tapered male iron (3/4) then you just need to get onto the ecv so a 3/4 meter connection to 22mm should sort this out
Reply to Gas meter relocation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
