Discuss Gas Pipe exiting from side of meter box in the Plumbing Jobs | The Job-board area at PlumbersForums.net
JLS
Is it permissible for a gas pipe to exit from the side of the meter box?
Depends on the meter box if there's a pre knock out and manufacturers allow it then yes
Didn't even know there were different types:(. It's just a standard one as far as I'm aware. I've been told it was OK so long as the exit was sealed. I've attached a picture of the box in question. (Kind of obvious now that I've posted it !! :rolleyes:)
Just to clear up any confusion, I'm trying to work the figures for an upgraded boiler as part of my portfolio. Guy that has agreed to supervise me did so rather reluctantly so I want to present the most complete and accurate plan that I can
That’s the bottom mate. Not the side. :D:D:D
Funnily enough I was aware of that, perhaps my post prior to yours wasn't clear. That's the current install, but working out the pressure drops I feel that the supply needs to be upgraded and it would be a lot easier to exit through the side of the housing.
Usually a single bolt in bottom centre of the cover, when undone it pulls forward and lifts up exposing the meter and wall bracket. Makes it easier to work on the pipe work if you ever need too. They have a notched fitting around the pipe that's integral to the box design. They usually have a couple of cable ties holding the door on where the hinges used to be.
Updated a few like that and always run the 28mm the same way as its running now no need to notch the box
28 won't do it in this case. Well not by my calculations. Trouble is the property is an extended bungalow with the meter at one end, one boiler at the other end and another boiler and a cooker in the middle
I could have sworn we had a problem given to us in college where we were shown that we could make it work by increasing the pipe size further down the run but I've since been told that you have to come off the meter in the largest size pipe that you're going to use. I'm not sure there's enough room to jump it up to 35 and get it round the corner, hence wanting to come out the side.
you can get 35mm elbows
True I was just trying to keep costs as low as possible as the customer is family
and looks better from the bottom
depends on the loading but 10 elbows and 40m of pipe at 34kw is ok for 28mm tube
It's not just the elbows though is it, it's another three elbows a meter connector and at least a meter of pipe. about £30 worth
where you getting your fittings from normally around £20 max
BES was the cheapest I could find, that 35mm pipe 'aint cheap is it
<edit> just checked £35 once you've added the VAT from BES assuming the cheapest meter connection
Your local merchants eg city's plumbs etc
I tried Wolseley and they got no where close (£53 a length for the 35 iirc and I don't think that was with the VAT)....check these prices.. I swear they don't want my business for some reason
Reply to Gas Pipe exiting from side of meter box in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a...
I wish to add a second boiler to my existing meter. Location 20m away. Underground run. Can l use 32mm yellow pipe with copper tails at each end...
We have an old gas pipe in the understairs cupboard. The previous occupants had the gas meter moved, but this old pipe remained. This pipe goes...
I have a domestic gas meter located at one side of my building and my boiler/cooker (only 2 gas devices) on the other side of the building. There...
3K
hi i am currently moving home and i have been told by a plumber that the enc pipework into/out of this gas box would not pass a gas safety test. I...
