Discuss Gas Pipe in PVC pipe in the Gas Engineers Forum area at PlumbersForums.net
I am new to the forum. Trying to seek some advice on gas pipe being laid in concrete foundation.
If I put the copper gas pipe in a PVC pipe and then laid in the concrete foundation...can this method work.
No as if you have an escape it’s not good
There’s rules and regs for it
Well if he is then he know he needs to be licensed and insured and permits raised with the local establishments
Hi Shaun, I'm sensing a level of irritation in that reply and I'm not really sure why?
I thought it would be good to be able to point people in the right direction even when we cannot actually give advice and I don't think we can assume he will know the US rules just because he is an American. I just thought at least in the UK we'd be able to help by referring him to a Gas Safe installer which would be the acceptable procedure, but I didn't know what the New-York state equivalent procedure was for gas installations.
What you're saying then, if I follow you, is unless he's got his contractor's licence (license) for gas, he needs to find a licenced installer to carry out the work as he cannot DIY it even if he does follow his state's code? If he needs to use an approved contractor, I agree there's no point him knowing the code himself.
No no irritation just sounds like he’s trying to do it himself but yes they need to be licensed for gas and pull permits from there local office
Reply to Gas Pipe in PVC pipe in the Gas Engineers Forum area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
