Discuss Gas pipe installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jase158
Got a friend who runs a takeaway, he is doing it up and wants a new gas pipe, feeding 2 x grill and 1 x kebab machine. I would not be installing the machines as all on hoses. so just up to the bayonet. I am looking for excuses to not do it as believe he may change it and put it under my gas safe number. I have cookers, do these appliances have separate accreditations? If I install the pipe in a shop is this commercial even though it is not above 70kw or 0.035 or 75mb (may have got these numbers wrong, cant remember them, could look but hopefully everyone should get the idea) and just for future reference, can I just install gas pipe or does it have to be connected to every appliance before turning it back on?? if I can, does it need to be notified to gas safe?
you should be ok as not exceeding pipe volume. not sure about appliances itself.
that's what i'm stuck with?? do you need to notify a gas pipe? what stops anybody fitting a gas pipe and just saying an engineer done it?
you could probably just invoice for pipework so you would have proof or even better, call Gas safe to be sure
What size is meter? Igup/1b tells I what u can an cannot do. If there is a ISo and test point after meter in an can install upto 35mm . I have had this issue and called GS they said ok asking as not exceeding iv. But catering is a bit specialist..... Ventilation Interlock and solenoids, fire suppression .
That's what I was worried about the most as theoretically it is commercial premises, but it doesn't exceed 1B. But the extractors were covered in crap and no interlock and don't know anything about interlocks, solenoids or fire suppression!! definetly passing this one on.
Reply to Gas pipe installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Am I the only one struggling to find appliances' manuals online? I know it's hard enough with cookers and old gas fires but I've just been unable...
We have an old gas pipe in the understairs cupboard. The previous occupants had the gas meter moved, but this old pipe remained. This pipe goes...
Hi, I’m having a gas cooker pipe capped off. The GS registered plumber/ fitter, has told me that to do this, he’ll also have to service the combi...
Our House is now fully Heat Pumped, insulated and we have had the Gas Meter Removed. We have a 1950s foldaway Cannon Gas Grill which is on the...
I've had a burst pipe under bathroom floor. Ive had it dug up and made safe with the affected pipe cut and end caps fitted. The pipes are cover...
