L
Leemckie91
Coupd someone tell me how i gas rate these smart meters? Iv had a play about with it but cant figure out how too do it.
cheers.
cheers.
Discuss Gas rating the new smart meter? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Start your 2min count as you press '9' 4times. Take your reading eg. 1234.123.Is it a utilita meter? If so you have to go in through the menu using number 9 to select. If I remember rightly it's volume test or something on those lines.
Press b on your start time press 9 3 times when u see volume test you will have a few numbers before a slash after the slash record the 3 numbers after the slash ignore the 4th number after slash let meter go to sleep press b on the two mins and record the 3 numbers after slash ignore 4th
Reply to Gas rating the new smart meter? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
