Discuss Gas safety engineer Norwich install LPG hob and bottles in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
oddball
Hello,
I have purchased a Calor Gas Cooker Hose kit TB 1053) and a automatic changeover kit (TB 1029) together with a 6m length of yellow Kuterlex tube 15mm * 0.7mm
The pipe needs to be run down a wall outside and buried for approx. 3ft. then run up an outside wall and in the house. The hole will be dug. The connection is for a 5 ring gas hob only - the hob will be fitted at a later date.
The location is Potter Heigham and I am looking for quotes to connect this up.
[h=1][/h]
Reply to Gas safety engineer Norwich install LPG hob and bottles in the Plumbing Jobs | The Job-board area at PlumbersForums.net
