Discuss Gas in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dianne
Hi, we had a new boiler installed about 18 months ago, since then we have had to call a gas registered plumber out to help with some central heating issues. During this time he did a gas test involving all our gas appliances which resulted in him saying that there wasn't enough gas getting to our boiler to cope with the demand if all 3 appliances were being used at the same time. We then called the gas installers out who re-tested and said that the readings were fine. This was mentioned to the plumber who said the readings were too low with the answer that they were wrong which has put a niggling doubt into my head, is there anywhere you can go to get an independent test just to put my mind at rest. Many thanks
Great advice. I would add if you require any further help from us that you need to register with us rather than just posting as a guest
Reply to Gas in the Plumbing Jobs | The Job-board area at PlumbersForums.net
