Discuss Gledhill Pulsacoil A Class???? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Riley
Super Moderator
S. Mod
Subscribed
Anyone got experience with these thermal stores?
got one that is barely producing any hot water I have zero experience does anyone have any pointers please?
cheers
Is the store itself hot but cold water at the taps , check blending valve .
Check little f&e has water in it .
Main thing on these
is immersion heater stat is goosed
Thanks guys
Problem appears to be good hot water for maybe half a baths worth
Then stone cold and doesn't heat up again till next off peak.
As I say my understanding of these is limited but from reading the literature they are supposed to be similar to a Combi with instantaneous hot water. Are the tenants expecting too much?
it sounds like its just not getting to temp mate , try a stat , they use cotherm stats (or did do ) not the best IMO
Thanks fella I'll have a look
It's expensive but their technical is pretty good, and there's normally a couple of dip switches to press on the pcb which then gives u temperatures etc.
Reply to Gledhill Pulsacoil A Class???? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
