Discuss Glow.worm boiler explosion. in the Central Heating Forum area at PlumbersForums.net
My LPG Glow.worm Ultracom 30 sxi boiler has exploded in some way. The front has blown open and the casing has buckled. (I was on holiday at the time. Thermostat left set at 16deg.) Annual Service four weeks ago. Boiler and heating still working! Any suggestions on cause?
Turn it off and leave it off also time for a new boiler sorry to say
Thanks. Guessed that would be the case. Just wondered what could have happened especially as advised by engineer at service it was in excellent nick!
Have they every cleaned inside the boiler eg stripped it down ?
I’m guessing it didn’t light first time and when it fired the second the extra gas made it go bang maybe
I hope they replaced the burner door seal and nyloc nuts when they cleaned the hex & burner as required, & LDF the GV inlet. This as previously mentioned needs turning off, isolating and reporting to gas safe & riddor for investigation. DO NOT USE!
[automerge]1574760104[/automerge]
Still it should not go bang even if it does not light first time. Should just go to lock out after 5 failed attempts should it not?
There are a number of reasons that could have happened and they may be unrelated to the Engineer. It is important you have this investigated for obvious reasons. There are others with the same Boiler, so if there is a fault it needs to be dealt with very soon.
Thank you. Have requested an engineer assessment and will ensure it is followed up.
mains gas shouldnt but lpg is a different animal. as lpg is heavier than air and it may not for whatever reason have all been purged out of combustion chamber on ignition sequence and has sat in bottom of boiler waiting for an ignition source
[automerge]1574797740[/automerge]
Reply to Glow.worm boiler explosion. in the Central Heating Forum area at PlumbersForums.net
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On...
The problem is, my ideal boiler logic heat h15 keeps on burning (igniting flame icon on) all the time, all day long, regardless of the programmed...
4K
Deleted member 120897
I have just moved into a late 1990s new-build house with a small bore (about 1/2" OD pipes) gas fired boiler central heating system. All the...
Hello. I wonder if someone can help. We have noticed 2 issues in our house over the last couple of weeks . We have a Glow Worm Ultracom 24cxi...
My heating system comprises an Ideal Logic 12 boiler located downstairs and a Gledhill OV SOL cylinder located upstairs . The problem is that when...
