Discuss Glow worm boiler serial number age in the USA area at PlumbersForums.net
G
Girl85
Hi I am buying a property with a flow worm flexicom 24 cx boiler. I am trying to find out age of boiler or installation date. I have the serial number. Is there a way I can check this pls
Old do you have around 14 years tbh new boiler time
Yes but you would have to phone gloworm up but if you post it up I can give you an approximate
I have similar issue. Flexicom 30 CX
Considering getting new one as repairs gender but if old might as well invest rather than drag on.
Serial number is 2000463986-04
2000 so hasn’t done too bad
Used to fit these many moons ago a 20 year old boiler needs replacing in all honesty, Glowworm have a replacement at a reasonable cost I changed a Glowworm ultimate for a Glowworm compact recently it was a rental property so the costs had to be kept to a budget. Kop
Reply to Glow worm boiler serial number age in the USA area at PlumbersForums.net
