Discuss Glow worm bypass seals in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
Hi folks, anyone know what seals I need for the boiler below. Cannot find out if it is just the o'rings or seals as well.
Cheers
Cant say for definite on this model, but the divertor valve / bypass normally on the valiants/glowworms have two slightly square(flat one side) shaped o-ring seals cant help you with part number though just been to the van i have one in there but no part numbers on the exploded diagram.... useful.
Cant say for definite on this model, but the divertor valve / bypass normally on the valiants/glowworms have two slightly square(flat one side) shaped o-ring seals cant help you with part number though just been to the van i have one in there but no part numbers on the exploded diagram.. useful.
Thanks. Turns out in the end all it needed was to be tightened up a tad more. Well, no call backs as of yet any way
Reply to Glow worm bypass seals in the Plumbing Jobs | The Job-board area at PlumbersForums.net
