Discuss Glow worm flexicom 18hx how to fill water + no pressure gauge??! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sg_fletch
Hi, hopefully somebody can help me with this. The boiler in our house is a glow worm flexicom 18hx but it doesn't seem to be heating the downstairs radiators even though they've all been bled. I'm putting this down to lack of pressure and that fault code comes up on the boiler if I turn the thermostat upstairs off and the one downstairs on full.
however, there is no pressure gauge I can see to check, and I can't work out where the tap is to let water in?
i have attached some photos to show the layout.
If anyone can help I'd really appreciate it as it seems it should be a fairly simple operation which I should be able to do myself.
thanks
airing cupboard
It's a heat only boiler, open vented so won't have a built in pressure gauge
There will be a small tank in the attic (probably, but if not attic, somewhere above the highest radiator)
The problem you describe is either down to sludge or a failing lump, or a bit of both
This could be open vented system or sealed system, have you got a small red tank any where on system ? or tanks in loft ?
Looks like a combined feed/vent on the tee before the pump
Yes you are more than likely correct ! But I never take it for granted, some people do strange things, maybe OP can come back and give us more information
Your system is working on an s plan call for hot water and make note of which zone valve opens then turn the call for hw off then call for up stairs heating make note of that zone valve then turn off then call for down stairs heating and make note of that zone valve then turn off.(turn each demand off as soon as the valve opens you can write on the valves hw chu chd or what ever you want) my guess is the zone valve has failed or only opening slightly and the flow hasn't got no where to go and causing the boiler to lock out due to the sudden increase in temperature.or you have an air lock down stairs which will be fun to get rid of but it can be done quickly and easily.
Reply to Glow worm flexicom 18hx how to fill water + no pressure gauge??! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
Can anyone tell me of a boiler equivalent to a Glow worm micron 30ff. I am not sure what one I should get?
The flue for a glow worm micron 30ff is apparently obsolete but there must be other flues that would fit it surely, it's just a standard 100mm...
I've got a Glowworm Flexicom 24hx boiler and I'm trying to unplug the installer cartridge in order to wire up the ebus connection inside. From...
I am looking for some basic advice please My house is on two floors, approx 240m2 and a spacious loft with good headroom and access. Glow Worm...
1K
