Discuss Glow worm Ultracom 24 firing issue in the Central Heating Forum area at PlumbersForums.net
Went to a customer today their glow worm Ultracom 24 HE goes to fire up then cuts out turning the heating pump off, then does the same again before firing and running. Occasionally shows the flame is lit on display but flow temp doesn’t go much past 26. Then if you turn off and try again sometimes it fires up straight away and runs? Anyone have any ideas? I’m gas safe registered, but not for that long and haven’t done too many break downs
flame sense prob ok ?
Haven’t checked that but doesn’t even get to flame point, fan ramps up then cuts out does this two or three times before running
Aps then I would check first
Reply to Glow worm Ultracom 24 firing issue in the Central Heating Forum area at PlumbersForums.net
  • Article
Sonya K
