Discuss Glow worm ultracom 30cx - setting combustion?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mejmag
Glow worm Ultracom 30cx combi.
Was unable to set boiler into min or max rate in order to check/set co2 readings.
MIs say press reset button then quickly press and hold the "+" button until "Hi" is displayed, but there is no "+" button on the user control?? Took off the back of the control panel to look for potentiometers but there were none, only the back of the heating potentiometer??
Analysed it it on hot water and co2 was 9.2, ratio-0.0007 so all good but am at a loss as how to check on min and max rates??
anybody else come across this?
cheers.
Reply to Glow worm ultracom 30cx - setting combustion?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Glow Worm Ultracom 30sxi boiler that provides central heating and also heats a hot water tank. There are no error codes shown on the...
3K
About 12 days ago attended a boiler lock out. Apparently another plumber was there a week before to and adjusted the photo cell. .. It is a grant...
3K
Boiler was working fine but now whenever I take a shower the hot water fluctuates from hot to luke warm. Looking at the boiler display, I can see...
2K
This is a long shot-( this post was originally sent to StevethePlumber but I havent heard back from him as yet) I have a glow worm ultimate ff...
5K
hi, Im looking at a glow worm ultracom 18hxi that heats up to mid 70s/80s works for about 20 mins, then goes into low gas mode (one flame on...
2K
