Discuss Glowworm FF60 Lockout Problem in the Central Heating Forum area at PlumbersForums.net
Hi - Can you help? I have a Glowworm Micron FF60 Boiler and it has gone into "Non Volatile Lockout" - Reset light is solid green, boiler and everything restarts after turning off the temp dial and back on again. The fans work, it produces heated water, the pump is spinning (albeit its pretty quiet). After a couple of minutes the boiler switches off again. Its a conventional boiler not a combi. Just before it switches off you can hear the boiler sounds like a kettle warming up, as if the water is being heated but not going anywhere - not especially noisily but I don't recall hearing those noises before (its in an outside cupboard so I'm not completely familiar with its noises, but this is predictable its getting too hot). For the brief few minutes it is on, the rads start to get warm (I have not checked upstairs rads only downstairs thinking about it).
So, in essence, everything works when its working - what could cause lack of flow and should boiler make kettle type noises - I assume the temp thermostat is tripping out the system, but is it because it is too hot or because its faulty? The boiler will turn back on immediately if you reset immediately
Check pump is actually spinning
I took off the big screw and spun the inners - it moved freely. When powered up it spins fast. The pipe into it and out of it gets hot and the rads downstairs and upstairs get heat - as does the upstairs hot water tank. Would this exclude the pump or still a possibility?
Can you stop the pump eg stick an old screwdriver in through the vent port (an old screwdriver) and if you use light pressure can you stop it ?
Sounds ok then but as it’s kettling it’s a circulation problem so something isn’t opening / getting the heat away
so what are the options - if it was scaling, would that not be a gradual process or take a long time to overheat if at the beginning - this cuts off after just a few minutes. Kettling I've described may be too strong a description perhaps, but It does sound like when a kettle is perhaps just started - No rumbling of boiling water or anything like that
Do the pipes feel hot eg around 50dc ?
Or it’s not pumping away enough
Reply to Glowworm FF60 Lockout Problem in the Central Heating Forum area at PlumbersForums.net
I have a green star ten yrs old keeps increasing pressure, feel on off filling valve not working, drain off to recommended, but after few days...
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
