Discuss glueing bath panel together and sealing to bath in the Plumbing Jobs | The Job-board area at PlumbersForums.net
the prob with that is I cant get a panel the correct size - hence the trimming.You don’t new panel required
90% of the time you have to trim panels down, have both skins detached from each other? What did you cut it with?the prob with that is I cant get a panel the correct size - hence the trimming.
they have detached along the top edge and at one end. not completely, but enough to allow the panel to flex., so if I could rebond the edges, it would stiffen it substantially.90% of the time you have to trim panels down, have both skins detached from each other? What did you cut it with?
The only thing to bond acrylic are solvent based, same as whats used with solvent weld pipe. It melts the two products together, you could try it but it may discolour the surface.they have detached along the top edge and at one end. not completely, but enough to allow the panel to flex., so if I could rebond the edges, it would stiffen it substantially.
that shouldnt be a problem as it only the inside surface that needs to be bonded. Or are you saying the discolouration will leach thru?The only thing to bond acrylic are solvent based, same as whats used with solvent weld pipe. It melts the two products together, you could try it but it may discolour the surface.
heat might distort it more, i would think.glue gun maybe
It could do, it's only thin so you may see some discolorationthat shouldnt be a problem as it only the inside surface that needs to be bonded. Or are you saying the discolouration will leach thru?
Reply to glueing bath panel together and sealing to bath in the Plumbing Jobs | The Job-board area at PlumbersForums.net
