Discuss Going from 10mm JG direct to Radiator TRV? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
So been trying to search this for some time and finding mixed results, I have 10mm JD Speed fit piping coming out the wall and hoping to use it on the original TRVs, things that keep popping up are
these JG stem reducers, but doesn't seem right that the value would go onto the end? wouldn't it cause damage?
or something like this?
Any help be much appreciated
https://www.NoLinkingToThis/p/drayton-push-fit-reducing-90-trv-adaptor-elbow-f-10mm-x-m-15mm/9970r
are these the same thing? (nearly half the price) "PEGLER TERRIER CHROME-PLATED BRASS PUSH-FIT REDUCING 90° ELBOW F 10MM X M 15MM (28509)"
sorry I'm unable to post links to Screwfix... as it pops up a message saying that it's most probably spam smh
Yes but them ones the 10mm isn’t removable afterwards so once pushed in you have to cut it
Reply to Going from 10mm JG direct to Radiator TRV? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I am trying to workout in what order my radiators heat up in order to then balance them. I am able to figure out which radiator pipe is the...
Hi All! Bought a house recently, and we have been having the most frustrating issue with a very loud humming noise that intermittently comes and...
2K
  • Solved
Hi There, I want to swap out my old valves for TRVs but the threads are different sizes, and I'm unsure how to resolve it. My current existing...
2K
Daley power
Hello I want to replace the old single panel rad in the bedroom with a K2 double panel Stelrad one. I think I'm OK in general and relatively...
M
Hope this is in the right forum. We've a utility room radiator with 10mm pipework; fitted about 6 years ago it has a BOSS TRV which has failed...
3K
