DanielDeronda
Hi
I've got a problem when trying to reconnect my U bend underneath my kitchen sink.
I've been trying to clean out all the gunk that has built up from using the sink, so I removed the u bend pipe underneath the sink, removed any extraneous matter that may be causing any blockages.
However, I have a problem when reconnecting the pipe. It is a compression joint. One of the ends connects perfectly, but for some reason, I can't connect the other end. I have a couple of washers (1 black & rubber, 1 blue & plastic) & the white threaded compression cap. The black washer has a tapered feel on 1 side.
It has worked fine before, but stupidly I forgot what order the washers/cap go in & how they connect to the pipe.
Can you please advise what I need to do? I don't want to bring out a plumber as I'm sure it's a simple job!!
