Discuss Grant oil burner set up in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Evening,fitted a few oil boilers,usually Grant. Fitting one just now and noticed that the burner is different. Is there something I need to look out for when setting up?
Just follow the MIs and you will be ok.
If you are not altering the boiler power output, then the factory setting will be correct except you need to do the usual analyser adjustments of air
Reply to Grant oil burner set up in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
