Discuss Gravity to sealed question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
GQuigley67
got an open vented electric thermal store I want to convert the heating system to a sealed system due to pipework being above the F&E. boiler is in airing cupboard and pipes drop from loft to rads, the boiler is 9kw so I need a plate heat exchanger, was wondering if taking one from a Combi would work if somehow one had suitable connections, sure I have about 5 combis in my lock up.
Failing that, anyone recommend a reasonably priced PHE up to the job ?
No it won't sorry and bss do some very good boss branded ones
So you want to keep the thermal store open vented ?
The boiler needs to be open vented, I need to change the heating to sealed so seperarion with a PHE is required.
Kinda messed up on my design and was in sealed system auto pilot mode not realising it was an open vented thermal store, so system has major air issues now, hoping it's not gonna be too much of an expensive mistake, heating works just major gurgling at thermal store. Still money on the job for couple hundred to convert but hoping PhE is below £150 lol
Easily last little one I got 50 kw was £62 plus the cat
Glad to hear, was expecting Combi PHE prices lol. Last 80kw one I got was crazy money
How much I can get a 150 kw for round the 200 mark plus vat
It was a Worcester one, last year probably around 400-500, was from plumb center though and probably didn't have terms on commercial.
If their cheap then I'll just go to BSS and buy one, least they can assist with what adapators I need. Would hate to order online and it wasn't BS
Am i missing something here 9kw boiler in the airing cupboard? and shaun is sourcing a 22kw plate beware you have made one error double check before you do this . cheers kop
It's only the max capacity of the plate
Smallest they do
No unless I'm thinking of something else
Reply to Gravity to sealed question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath the boiler is difficult with lots of obstacles, is it okay if I run soldered copper over / across the top of the boiler? It'll be about 4" off the top...
