Discuss GREENSTAR 30CDi grumbling noise after change of gas valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, can anyone suggest a solution here
My boiler stopped with ER fault, re-setting did not help since same fault after few minutes. The Engineer (corgi reg) changed the gas value and all was Ok for a day.
Then the grumbling/vibration noise started, initially when the hot water came on. The engineer came back and fiddled with the gas value setting, all well for few hours but that evening same thing. The Engineer tried one more time but noise/vibration still there, couple of times boiler has stopped with "ER" fault but has started back after re-setting. What I have noticed is
- was with hot water coming on, now random
- reducing the temp control on boiler sometime helps, although this morning I raised it from 4 to 5 and the noise stopped
The Engineer is coming back on Monday but I am not convinced he can resolve this issue
- could the valve be wrong part number ?
- could it be faulty
Any ideas please or should I look for a different Engineer
thanks
Gasmk1
Thanks, is this simple to do?
My gas Engineer has had three attempts so far and am little concerned
thanks
If you're concerned I'd get another engineer to take a look. Maybe put an ad here..[DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
We can't offer repair advice on the open forum.
Reply to GREENSTAR 30CDi grumbling noise after change of gas valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
Hello, I have just moved in to a new flat this week and have a problem with noise coming from somewhere around the top of the boiler. It's a loud...
Hi everyone! My Worcester Greenstar 30CDi Combi boiler started making a rather loud juddering noise two nights ago. I bled all the radiators and...
Deleted member 120897
I got a problem with my boiler,it's got some vibration when it starts to work,it doesn't fire up unless I duck tap and blank half of the air...
Hi all. I hope you are well. Need some advice on this boiler and fault. E229. Went there and condensate was totally blocked so cleaned it and...
Started getting a random F7 fault on our gas boiler, called out a gas engineer to have a look at it. He gave it a good look over and checked and...
