Currently reading:
Greetings Looking for direction
Discuss Greetings Looking for direction in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Mr Wilson
Greetings folks new member here so i wont waste anyones time just after some direction to some common discusion threads so i can start reading.
Im starting a major project a full install gas central heating system. i got me a certified installer (german) for the boiler and everything gas related but my job is all the internal plumbing to and from rads all wall chasing and heating to the kitchens and bathrooms. its a 3 story building with about 16ish rads oh and im in germany but dont speak german only australian... fun
links i need pointing to to start with
plastic piping in brick and rendered walls (i know copper is best but with this size job plastic is worth a look )
thickness of piping for variances in distances and pressures
single pipe circut or double to and from rads
german plumbing regs and laws in aussie
thankyou fellas look forward to hearing from you im sure ill have many questions over the next year.
welcome along.
the German fitter will be the best to advise you.
we deal with the regulations that apply here???
but plenty of bedtime reading to look through anyway.
cheers mate. i contacted a local guy and a translator and spent a few hours grinding threw the threads some great stuff here...
Its tricky to make suggestions here as the regs are bound to be different.
Plastics fine in the wall. I always run silver tape over them so they can be detected
Single pipe systems are not as good. Also with plastic its not just throw it in, there's a proper way to install it and commission it.
I also assume your having nothing to do with the gas pipework as plastic is a big no no.
Before you start id seriously ask yourself if you want to take on a project this size like this without the correct training, there will be plenty of unforeseen problems you will hit but good luck with it if you do.
hea ace yeah not touching gas line which would be copper and needs to be signed of on. As for running pipe threw the house germanys is a DIY dream land they even do all there own sparky work post mains.
Comming from australia done plenty of plumbin work meself out of necessity both copper and plastic as even though aussie dont let you do nothing ya self who can offord a 120 per hour trady to change a tap washer.
this is just my first brick build im use to timber stick houses we have there in Oz i brought all my tools with me but just need to study up on central heating systems as we use windows in australia.
the silver taps a great idea and i was heading towards a dual pipe S type setup and very room in the building requires full reno anyways so a few more chases and pipework aint that bad.
Renos = problems one gets use to it hence this forum...
Isn`t member called Matchless plumb from Germany?
Reply to Greetings Looking for direction in the Plumbing Jobs | The Job-board area at PlumbersForums.net
