Discuss Grndfos pump numbers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
gassman
I have a UPS 15-50 x18 pump. Can anyone tell me what the x 18 stands for?
The 18 is probably the length in cm. though usually expressed as 180 (mm)
Check that the number is 180, it's not usually written as 18.
You can get 15-50 130 and 180 pumps.
as above, its the length of the pump flat face to face.most domestic pumps are 130 or 180mm
It is 15-50x18 its a grey grunfos and used on Gledhill appliances.
I have 2 brand new ones on my shelf and wondered about using on a different system. the x18 is the puzzling part. Not sure if they can be used elsewhere?
Reply to Grndfos pump numbers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
