Discuss Grndfos pump numbers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The 18 is probably the length in cm. though usually expressed as 180 (mm)
Check that the number is 180, it's not usually written as 18.
You can get 15-50 130 and 180 pumps.
as above, its the length of the pump flat face to face.most domestic pumps are 130 or 180mm
It is 15-50x18 its a grey grunfos and used on Gledhill appliances.
I have 2 brand new ones on my shelf and wondered about using on a different system. the x18 is the puzzling part. Not sure if they can be used elsewhere?
Reply to Grndfos pump numbers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
