Discuss Grundfos - mini pressurisation units in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E4gas
Has anyone every fitted a grundfos mini pressurisation unit . I've got to fit one as well as a low lost header tank ..
Much the same as any other.
Low loss header tank? You mean a buffer?
It still is in your world by looks of it old son!
You mean a low loss header or buffer tank?
Or a tank you're unable to find?
Or requires hiding?
Much confusion!
They are usually connected with an expansion vessel if changing from open vented.
Is this what you mean?
Are we talkin about the G/Fos mains booster thing ? that promises to deliver 14 litres per min to make you mis chosen combi deliver what the manufacture says in the destructions ?
If so I have an opinion.......if not i will keep quite. CHK
These units which boost up mains water pressure are a really good beano - all wras approved etc.
Think about it - good profit and fitting rates - unit is easy to fit
made by a good manufacturer. NOW HERE IS THE FUNNY BIT.
Once you fit one unit in a street it will affect the neighbours WHO
WILL ALSO WANT ONE - when the whole street has one they are all
back at square one sharing out the same pityful mains wayter supply but us lot and Mr. Grunfos have made loads.
centralheatking
If you study Maslow's Hierarchy of Needs you'll find water very much on the base tier.
Reply to Grundfos - mini pressurisation units in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
Hi All, I am looking to take my bath out and fit a shower. Regards to tanking. Is it ok to just seal everything with plastic rather than just...
