Discuss H2 Panel to connect wet back wood stove and oil fired rayburn in the USA area at PlumbersForums.net
I am considering using an H2 panel to connect a woodburner stove with a back boiler to an oil fired rayburn. I have seen that serveral years ago there was some talk of the H2 panel but have been advised that using such a system is expensive to fit and not that efficient. Has anybody got any advice and or experience of difficulties with this system.
Thanks in advance!
My goto choice of twinning systems. Buy the panel and a pump and away you go. Plenty of info from heating innovations as well.
Reply to H2 Panel to connect wet back wood stove and oil fired rayburn in the USA area at PlumbersForums.net
J
Hi all, I am a plumber but I do not carry out works to boilers as the majority of my is bathrooms so I am not gas safe. I have completed a...
We got an open fireplace with a back Boiler it also feeds the radiators with a pump, the water goes via the back boiler through a coil under a hot...
Interested on thoughts on this (I've also posted on another forum but thought this might be a better place to ask); Long time lurker, have...
4K
My current system is a wood fired boiler, and /or oil boiler the wood boiler heats my garage, home (hydronics) and my indirect HW system. the...
Hi all, I’m looking to install a central heating system in a 3 bed 1860’s solid stone walled cottage. It only has a coal fire at present so it...
2K
