Discuss Halstead ace high problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pete1
Hi
Im looking for some help with my boiler...it was running fine untill a week ago when i stopped getting hot water...i found i could get hot water with the heating turned on and looked on line and found a lot of people mentioning the diaphram in the flow valve....i changed that and still no joy so i changed the diverter valve completely.
Now after replacing the flow diverter i have no ch or hw ..... when i turn the boiler on it fires up for a second then cuts out and the power light flashes
Any help greatly appreciated
Pete
Get a gas safe engineer in and stop messing with a gas appliance when you're clearly out of your depth.
Thread closed.
Reply to Halstead ace high problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the outputs goes to a 2 port diverter prior to the Megaflo (I believe this is some safety feature). I have run into an intermittent problem where some...
 Our heating stopped working today. We've got a Veissmann boiler that's under a year old, and an older Megaflow cylinder, and two diverter valves (all about 10 years old). We also use a Hive thermostat.
 When I boost the hot water with Hive, the receiver near the boiler shows it's...
Hi All, Hope somebody can help :) I have a vented HW system with a pressurised Ch system but got bit of a annoying issue, when the hot water comes on all seems ok then after about 15/20 mins i started to hear a trickling noise from hw cylinder which i can also hear in the boiler. The central...
M
I've got a heating boiler which heats up the water in a tank located in a cupboard upstairs and then from there I get hot water & hearing. I get hot water ok but the heating doesn't come on when turning the thermostat to a higher temperature. I've got a 2 way motorized diverter valve which would...
M
Hi, My gravity fed hot water slows to nothing over 30 seconds. when tap turned off for 5 mins, tap will run again for 30 seconds etc. I have tried the mixer tap/air lock trick about 10 times now and still not fixing. I have drained the HW tank a little so I can inspect the 22mm out pipe at...
