Discuss Halstead ace high problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pete1
Hi
I looking for some help with my boiler......it would only give me hot water when the heating was on and after looking on line i found that the problem was likely to be the diaphram in the flow valve. I changed the diaphram but still had the same problem so i changed the whole valve unit. After replacing it and refilling the system i find that the boiler fires up for a few seconds then cuts out and the power light flashes. ......i dont have any hot water or heating at all now.
Does anyone have any idea what the problem could be?
Pete
Get a gas safe registered engineer in and stop fiddling around with a gas appliance when you are clearly out of your depth. No DIY boiler repair advice is given on this forum.
Reply to Halstead ace high problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have done pressure test for 2" high pressure pipe line by closing the pipe with rubber plugs at the ends. It was 3 bar and I kept it for 24 hours. Its shows a pressure drop of 0.5 bar. The pipe line is fully exposed and I couldn't find any leak on them. What might be the problem. If somebody...
Hi, Later this year I am going away for a 2 week holiday and as the weather will be warm there is no need for the heating to be on and arguably no need for me to needlessly heat hot water. My intention was to turn the boiler off along with the mains water when going away. Now, I have heard...
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
