Discuss Has anyone fitted a combined bath trap and pop up waste like this one, who is manufacturer? Thanks in the USA area at PlumbersForums.net
Not one I’ve seen before, are you not able to replace with a standard one?
No, there is no overflow hole in the standard position, the control knob is on top of the bath to the left hand side of the taps, there are two plastic hoses running up from the trap , the whole thing is weird.
Any markings on the waste anywhere? Make of Bath? - perhaps it was supplied with it?
No makers marks visible, I've looked at dozens of pop up wastes on Google but can't find this one, the two pipes in the photo are actually the overflow pipes, I've worked that out so far, might be able to disconnect them and pull the trap out with the pop up mechanism and see what's going on, but would like to find out if spares are available. Thanks
Ideal standard sorry to say discontinued was a 70lws
Surely one is the overflow and the other the pop up
Yes, the two pipes in the second photo are the overflow arrangement, (bit of an odd idea), the pop up mechanism is in the box type fitting below the bath, I have managed to identify the unit, although it is obsolete I think one company on google has one in stock at around £140, I might just remove this old unit, cut a new hole in the bath and fit a standard overflow with a plug, those pop up wastes are a pain when they go wrong, as they all eventually do. Cheers
Where does it overflow then if no existing hole?
Yes like I said it's a crazy design, the two pipes in the second photo go up behind the bath and join together just below the taps, as the bath fills up the water rises up one pipe through the plug hole to the same level as the bath. It looks like the seal to the waste is in the box below the bath not at the plug hole. If the bath over fills the water goes over one pipe and down the other into the trap. You have to ask who designed this and why.
It's called how to over complicate something for some reason that made perfect sense at the time.
The plug must seal below the level of the upper overflow outlet from the trap then?
Hi, thanks for your reply, that's the exact same thing, I think one company on google has one but it's £140 + delivery, I'm just going to scrap it and fit a standard overflow to the bath, I'll only need to cut a hole in the bath for the overflow outlet. Cheers Steve
Reply to Has anyone fitted a combined bath trap and pop up waste like this one, who is manufacturer? Thanks in the USA area at PlumbersForums.net
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
