SurreyWinter
A couple of days back I had a plumber around to sort out a leak in my loft. Turned out to be a the top of the cold water header tank (with a pile of insulation foam) that had collapsed into the tank and as a result had caused the stopcock to be blocked into "on" position. Combined with the fact that the overflow pipe was also blocked by insulation foam had led the the tank overflowing and causing the hall ceiling below to collapse.
Anyway he's now recommending replacing the cold water header tank with a sealed unit costing around £300 + labour. Is this replacement necessary and is this a reasonable price to pay?
