duffsparky
My central heating has broken down and I can't afford to fix it coz I'm going through a divorce. I'm using the immersion heater for dHW but it gets cold very quickly; this is probably due to the rest of the house being only 2 or 3 degrees above the ambient outside temperature (sometimes it's warmer in the fridge than in the kitchen brrrrrrrrrr- no bull, I'm monitoring the pipework temp so I can drain it should it get cold enough to freeze). The tank is a fairly modern pre-lagged one covered in yellow polyurethane(?) foam; so I'm guessing that, as there are no leaks I can find, the heat loss is via thermal convection up the vent pipe.
I seem to remember quite some time ago reading an article about connecting the vent pipe of a HW cylinder below the level of the cylinder outlet to prevent gravity heat circulation but I can't find that article any more or any other like it. See drawing below
Has anyone got any advice on this?
Thanks.
Thanks.
