Discuss heater for power flush in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plumbster3456
is there some type of heater you can buy to heat up the cold water in the power flush machine.
I have a power flush myself but sometimes its not possible to use boiler as heat source.
I have been looking for some type of heater that could plug into the wall and then through the whole in power flush machine
I'm sure I posted on this thread last night ...
I suggested one of those "school" heaters used for coffee/tea. (Obviously after making yourself a brew.)
lol I actually thought you were joking when you posted that on the other thread
LOL - I was thinking earlier today that it might be a helpful touch when replacing someone's hot water cylinder and they're going to be without hot water overnight.
The combimag will fit any powerflush machine. It has std 3/4" male connections.
Reply to heater for power flush in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
