Discuss Heating cutting out after 20 mins ish in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Mrharkin
Hi folks my central heating cuts out after 20 mins first of all to start the heating I have to press the reset button to fire it up rads get warm ish then cuts out I have both thermostats set to 30 I have bled all rads also I have noticedone that my expantion vessel in airing cupboard has no bar pressure at all this is and oil fired heating system
Difficult to be certain, from image, if red expansion vessel if off heating or hot water. Additional photos of expansion vessel and associated pipework might bring more response.
Reply to Heating cutting out after 20 mins ish in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Heating and hot water is not working. Plenty of heating oil. I have replaced batteries in thermostat and it seems to be working ok, showing flame...
Hello, I live in a two floor semi with a gravity fed conventional gas fired boiler (Potterton Kingfisher MF). The boiler is fed cold water from...
Hi guys, first post here So I have been boxing in a number of heating pipes that are throughout my garage since the boiler was located there by...
Morning All, hoping you can help me out with some advice. I have a triton AS2000x manual power shower, we had a power cut last night after the...
M
Hi, we have a back combi heater. Whenever the heating comes on it seems to lose pressure within a few hours and I have to refill each morning...
