Discuss Heating Problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
new b
I was helping a friend drain down his central heating system in the house
he had just moved in. I found that some of the rads bleeding valve had been over tighten to the point they had been rounded off, I bled the rads the best I could then refilled and again beld the rads best I could.When full I asked him to switch the heating on and nothing happend so I asked to switch the hotwater on the rads upstairs started to warm up but the down stair rads remained cold.
The pump for the system is upstairs near the hotwater storage cylinder and I think it is not working and would like to know if I'm correct
Are you sure the pumps not working.....you wouldnt have anything at all if it isnt.
If the rads are warming up in hot water mode, it sounds as though the motorised valve is at fault.
pumped or gravity ?? you will still get gravity circulatin on most domestic instalations due to poor design ,you will proberly find pump defective
if its a freebie job take center screw out and use a screwdriver to spin it free
if its a paying job replace pump
Reply to Heating Problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or...
Hi, I have 3 port value for HW & CH. Loft extension added many years ago so they added a T to go upstairs, only 2 rads up but 11 downstairs...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
Hi, I have just had my central heating system "upgraded" for a four bed-roomed detached house. The heating company recommended going from the open...
1K
Central Heating Pump - G Pump Force HE-RS25/6PWM-130 Hi, I would be grateful if someone could explain whether our CH system can cope with the...
